The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Install a CA certificate if you use StorageGRID with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
For ONTAP to authenticate with StorageGRID as the object store for a FabricPool-enabled aggregate, you can install a StorageGRID CA certificate on the cluster with System Manager classic (available in ONTAP 9.7 and earlier).
Steps
Follow the StorageGRID system documentation to copy the CA certificate of the StorageGRID system by using the Grid Management Interface.
While adding StorageGRID as a cloud tier, a message is displayed if the CA certificate is not installed.
Add the StorageGRID CA certificate.
The fully qualified domain name (FQDN) that you specify must match the custom common name on the StorageGRID CA certificate.
Related information
