The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Edit initiator groups with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use the Edit Initiator Group dialog box in ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the name of an existing initiator group and its operating system. You can add initiators to or remove initiators from the initiator group. You can also change the portset associated with the initiator group.
Steps
Click Storage > LUNs.
In the Initiator Groups tab, select the initiator group that you want to modify, and then click Edit.
Make the necessary changes.
Click Save and Close.
Verify the changes you made to the initiator group in the Initiator Groups tab.
Related information
