Review storage recommendations with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can review the storage recommendations that are provided for creating aggregates by using the storage window in ONTAP System Manager classic (available in ONTAP 9.7 and earlier).
Before you begin
You must have set up the cluster, network, and the support details.
About this task
You can create data aggregates per the storage recommendations or you can skip this step and create data aggregates at a later time using System Manager.
Procedure
To create data aggregates as per the storage recommendations, click Submit and Continue.
To create data aggregates at a later time using System Manager, click Skip this step.
What to do next
If you opted to create aggregates per the storage recommendations, you must create a storage virtual machine (SVM) to continue with the cluster setup.
