Clone LUNs with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create a temporary copy of a LUN for testing or to make a copy of your data available to additional users without providing them access to the production data. LUN clones enable you to create multiple readable and writable copies of a LUN.
You must have installed the FlexClone license on the storage system.
When space reservation is disabled on a LUN, the volume that contains the LUN must have enough space to accommodate changes to the clone.
When you create a LUN clone, automatic deletion of the LUN clone is enabled by default in System Manager.
The LUN clone is deleted when ONTAP triggers automatic deletion to conserve space.
You cannot clone LUNs that are on SnapLock volumes.
Click Storage > LUNs.
In the LUN Management tab, select the LUN that you want to clone, and then click Clone.
If you want to change the default name, specify a new name for the LUN clone.
Click Clone.
Verify that the LUN clone that you created is listed in the LUNs window.
Related information
