The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Edit initiators with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use the Edit Initiator Group dialog box in ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the name of an existing initiator in an initiator group.
Steps
Click Storage > LUNs.
In the Initiator Groups tab, select the initiator group to which the initiator belongs, and then click Edit.
In the Edit Initiator Group dialog box, click Initiators.
Select the initiator that you want to edit and click Edit.
Change the name and click OK.
Click Save and Close.
Related information
