Cluster peers with System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to peer two clusters so that the peered clusters can coordinate and share resources between them. Peered clusters are required for data replication using SnapMirror technology and SnapVault technology, and for data replication using FlexCache volumes and SyncMirror technology in MetroCluster configurations.
Generate a peering passphrase
Beginning with System Manager 9.6, you can generate a passphrase for the local cluster IPspace and use the same passphrase in the remote cluster when creating peering relationships.
Click Configuration > Cluster Peers.
Click Generate Peering Passphrase.
The Generate Peering Passphrase dialog window displays.
Complete the following fields:
IPspace: Select the IPspace from the pull-down menu.
Passphrase Validity: Select from the drop-down menu the duration for which you want the passphrase to be valid.
SVM Permissions: Select one of the following:
All SVMs to indicate all SVMs are permitted to access the cluster.
Selected SVMs to indicate specific SVMs that are permitted to access the cluster. Highlight the SVM names in the field that you want to specify.
Optional: Select the checkbox if the effective cluster version of the remote cluster is earlier than ONTAP 9.6. Otherwise, the cluster peering fails to generate.
Click Generate to generate the passphrase.
For a successful generation, a message displays that identifies your passphrase.
If you want to email or copy the passphrase, perform one of the following actions:
Click Email passphrase details.
Click Copy passphrase.
Modify the cluster peer passphrase
You can modify the passphrase that is provided during cluster peer creation.
Select the peered cluster, and click Edit
The drop-down menu displays.
Click Local Cluster Passphrase.
The Edit Local Cluster Passphrase dialog window displays.
In the Enter Passphrase field, enter a new passphrase, and then click Apply.
The minimum required length of the passphrase is eight characters.
The passphrase is modified immediately. However, there might be a delay before the correct authentication status is displayed.
Log in to the remote cluster, and perform Steps 1 through 4 to modify the passphrase in the remote cluster.
The authentication status for the local cluster is displayed as
ok_and_offeruntil you modify the passphrase in the remote cluster.
Modify LIFs that are configured for the remote cluster
You can use System Manager to modify the IPspace and intercluster logical interfaces (LIFs) that are configured for the remote cluster. You can add new intercluster IP addresses or remove existing IP addresses.
You must have at least one intercluster IP address to create the cluster peer relationship.
Click Configuration > Cluster > Configuration Updates.
Click Peer Cluster Network Parameters.
The Edit Peer Network Parameters dialog window displays.
If required, modify the following fields:
Intercluster LIFs: Add or remove intercluster IP addresses. You can add multiple IP addresses by separating them with commas.
Click Modify.
Verify the changes that you made in the Cluster Peers window.
Change the peering encryption status
You can use System Manager to change the peering encryption status for the selected cluster.
The encryption status can be enabled or disabled. You can change the status from enabled to disabled or from disabled to enabled by selecting Change Encryption.
Click Change Encryption.
This action is not available if the encryption status is “N/A”.
The Change Encryption dialog window displays. The toggle button indicates the current encryption status.
Slide the toggle button to change the peering encryption status and proceed.
If the current encryption status is “none”, you can enable encryption by sliding the toggle button to change the status to “tls_psk”.
If the current encryption status is “tls_psk”, you can disable the encryption by sliding the toggle button to change the status to “none”.
After you enable or disable peering encryption, you can either generate a new passphrase and provide it at the peered cluster or you can apply an existing passphrase that was already generated at the peered cluster.
If the passphrase used on the local site does not match the passphrase used on the remote site, the cluster peering relationship will not function properly.
If you chose Generate a passphrase, complete the necessary fields:
IPspace: Select the IPspace from the drop-down menu.
All SVMs to indicate that all SVMs are permitted to access the cluster.
Optional: Select the checkbox if the effective cluster version of the remote cluster is earlier than ONTAP 9.6. Otherwise, the passphrase fails to generate.
Click Apply.
The passphrase is generated for the relationship and displayed. You can either copy the passphrase or email it.
ok_and_offerfor the selected passphrase validity period until you provide the passphrase at the remote cluster. -
If you already generated a new passphrase in the remote cluster, then perform the following substeps:
Click Already have a passphrase.
Enter in the Passphrase field the same passphrase that was generated in the remote cluster.
Click Apply.
Delete cluster peer relationships
You can use System Manager to delete a cluster peer relationship if the relationship is no longer required. You must delete the cluster peering relationship from each of the clusters in the peer relationship.
Select the cluster peer for which you want to delete the relationship, and then click Delete.
Log in to the remote cluster, and perform Steps 1 through 3 to delete the peer relationship between the local cluster and the remote cluster.
The status of the peer relationship is displayed as “unhealthy” until the relationship is deleted from both the local cluster and the remote cluster.
You can use the Cluster Peers window to manage peer cluster relationships, which enables you to move data from one cluster to another.
Command buttons
Create
Opens the Create Cluster Peering dialog box, which enables you to create a relationship with a remote cluster.
Edit
Displays a drop-down menu with the following choices:
Opens the Edit Local Cluster Passphrase dialog box, which enables you to enter a new passphrase to validate the local cluster.
Opens the Edit Peer Cluster Network Parameters dialog box, which enables you to modify the IPspace and add or remove intercluster LIF IP addresses.
You can add multiple IP addresses, separated by commas.
Change Encryption
Opens the Change Encryption dialog box for the selected peer cluster. While you are changing the encryption of the peered relationship, you can either generate a new passphrase or provide a passphrase that was already generated at the remote peered cluster.
Delete
Opens the Delete Cluster Peer Relationship dialog box, which enables you to delete the selected peer cluster relationship.
Refresh
Updates the information in the window.
Manage SVM Permissions
Enables SVMs to automatically accept SVM peering requests.
Enables you to generate a passphrase for the local cluster IPspace by specifying the IPspace, setting the passphrase validity duration, and specifying which SVMs are given permission.
You use the same passphrase in the remote cluster for peering.
Peer cluster list
Peer Cluster
Specifies the name of the peer cluster in the relationship.
Availability
Specifies whether the peer cluster is available for communication.
Authentication Status
Specifies whether the peer cluster is authenticated or not.
Local Cluster IPspace
Displays IPspace associated with the local cluster peer relationship.
Peer Cluster Intercluster IP Addresses
Displays IP addresses associated with the intercluster peer relationship.
Last Updated Time
Displays the time at which peer cluster was last modified.
Encryption
Displays the status of the encryption of the peering relationship.
Starting with System Manager 9.6, peering is encrypted by default when you establish a peering relationship between two clusters
N/A: Encryption is not applicable to the relationship.
none: The peering relationship is not encrypted.
tls_psk: The peering relationship is encrypted.
