Change the status of a volume with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the status of a FlexVol volume when you want to take a volume offline, bring a volume back online, or restrict access to a volume.
If you want a volume to be the target of a volume copy operation or a SnapMirror replication operation, the volume must be in the restricted state.
If you want to take a NAS volume offline, the NAS volume must be unmounted.
You can take a volume offline to perform maintenance on the volume, to move the volume, or to destroy the volume. When a volume is offline, the volume is unavailable for read or write access by clients. You cannot take a root volume offline.
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the volume for which you want to modify the status.
From the More Actions > Change status to menu, select the required volume status.
Click Ok in the confirmation dialog box to change the volume status.
Related information
