System Manager Classic
Set up a network with System Manager - ONTAP 9.7 and earlier
Contributors netapp-mwallis
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to manage your cluster, nodes, and Service Processors by setting up a network. You can also set up DNS and NTP details by using the network window.
Before you begin
You must have set up the cluster.
About this task
  • Only those nodes that are up and running are listed for cluster creation.
    You can create LIFs for those nodes.
  • You can disable IP address range and enter individual IP addresses for cluster management, node management, and Service Processor management networks.
Set up a network when an IP address range is enabled
You can set up a network by enabling an IP address range. The IP address range enables you to enter IP addresses that are in the same netmask range or in the different netmask range.
Steps
  1. Enter a range of IP addresses in the IP Address Range field, and then click Apply.
    Option Description
    You have a range of IP addresses in the same netmask
    Enter the IP address range, and then click Apply.
    IP addresses are applied to cluster management, node management, and Service Processor management networks sequentially.
    You have a range of IP addresses in different netmasks
    Enter each IP address range on a separate line, and then click Apply.
    The first IP address applied to cluster management and other IP addresses are applied to node management and Service Processor management networks sequentially.
    Note
    After entering the IP address range for cluster management, node management, and Service Processor management, you must not manually modify the IP address values in these fields. You must ensure that all the IP addresses are IPv4 addresses.
  2. Enter the netmask and gateway details.
  3. Select the port for cluster management in the Port field.
  4. If the Port field in the node management is not populated with e0M, enter the port details.
    Note
    By default, the Port field displays e0M.
  5. For Service Processor management, if you are overriding the default values, ensure that you have entered the mandatory gateway details.
  6. If you have enabled the DNS Details field, enter the DNS server details.
  7. If you have enabled the NTP Details field, enter the NTP server details.
    Note
    Providing alternative NTP server details is optional.
  8. Click Submit.
What to do next
Enter event notifications in the Support page to continue with the cluster setup.
Set up a network when an IP address range is disabled
You can set up a network by disabling an IP address range and entering individual IP addresses for cluster management, node management, and service provider networks.
About this task
In the Networks page, if the IP Address Range is disabled, enter individual IP addresses for cluster management, node management, and service processor networks.
Steps
  1. Enter the cluster management IP address in the Cluster Management IP Address field.
  2. Enter the netmask details for cluster management.
  3. Optional: Enter the gateway details for cluster management.
  4. Select the port for cluster management in the Port field.
  5. If you want to provide netmask and gateway details to manage your nodes, clear the Retain Netmask and Gateway configuration of the Cluster Management check box, and then enter the netmask and gateway details.
  6. Enter the node management IP addresses in the Node Management field.
  7. If the Port field in the node management is not populated with e0M, enter the port details.
    Note
  8. Enter the Service Processor management netmask and gateway details.
  9. Enter the Service Processor IP management addresses in the Service Processor Management field.
  10. If you have enabled the DNS Details field, enter the DNS server details.
  11. If you have enabled the NTP Details field, enter the NTP server details.
    Note
  12. Click Submit.
