SVM Relationships with System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create and manage mirror relationships and mirror and vault relationships between SVMs. Storage virtual machine (SVM) disaster recovery (DR) provides disaster recovery capability at the SVM level by enabling the recovery of the data that is present in the constituent volumes of the SVM and the recovery of the SVM configuration.
Create SVM relationships
You can use System Manager to create SVM relationships to transfer data from the source SVM to the destination SVM. Creating an SVM relationship helps in recovering from a disaster as data is available on the source SVM and on the destination SVM.
The destination cluster and source cluster must be running ONTAP 9.5 or later.
The destination cluster must not be in a MetroCluster configurations.
Starting with System Manager 9.6, Fabric Pool is supported.
Click Protection > SVM Relationship > Create.
Select the SVM relationship type from the SVM Relationship Type list.
From the Source Storage Virtual Machine pane, select the cluster and the SVM.
Optional: To view SVMs that do not have the required permissions, click Navigate to the source cluster, and then provide the required permissions.
From the Destination Storage Virtual Machine pane, specify the name of the SVM that will be created on the destination cluster.
Select the option to copy the source SVM configuration.
Optional: Click
, update the protection policy and protection schedule, select aggregate, and then initialize the protection relationship. -
Click Save to create the SVM relationship.
The SVM Relationships: Summary window is displayed.
Click Done to complete the process.
Edit SVM relationships
You can use System Manager to modify the properties of an SVM relationship.
Click Protection > SVM Relationship.
Select the SVM relationship that you want to modify, and then click Edit.
Select the SVM relationship type.
If the SVM relationships were created before ONTAP 9.3, then changing the SVM relationship type from mirror to mirror and vault is not allowed.
Modify the protection policy, the protection schedule, and the option to copy the source SVM configuration, as required.
Click Save to save the changes.
Manage SVM relationships
You can use System Manager to perform various operations on SVM relationships such as initializing SVM relationships, updating SVM relationships, activating the destination SVM, resynchronizing data from the source SVM, resynchronizing data from the destination SVM, and reactivating the source SVM.
To initialize the SVM relationship, the source and destination clusters must be in a healthy peer relationship.
To update the SVM relationship, the SVM relationship must be initialized and in a Snapmirrored state.
To reactivate the source SVM, the resynchronize data from the destination SVM (reverse resync) operation must have been performed.
If you had selected the option to copy the source SVM configuration while creating the SVM relationship, then to activate the SVM relationship, the source SVM must be stopped.
SnapMirror license must be enabled on the source cluster and destination cluster.
The source cluster and destination cluster must be in a healthy peer relationship.
The destination cluster must have space available.
The source SVM must have permission for SVM peering.
You must break the SVM relationship to activate destination SVM, resync from source SVM, resync from destination SVM (Reverse Resync), and reactivate source SVM.
To reactivate the source SVM, the SVM reverse relationship must exist and be in a Snapmirrored state.
Select the SVM relationship, and then perform the appropriate action:
If you want to… Do the following… Initialize the SVM relationship
Click Operations > Initialize.
The Initialize dialog box is displayed.
Click Initialize.
Update the SVM relationship
Click Operations > Update.
The Update dialog box is displayed.
Click Update.
Activate the destination SVM Activating the destination SVM involves quiescing scheduled SnapMirror transfers, aborting any ongoing SnapMirror transfers, breaking the SVM relationship, and starting the destination SVM.
Click Operations > Activate Destination SVM.
The Activate Destination SVM dialog box is displayed.
Select the Ok to activate destination SVM and break the relationship checkbox.
Click Activate.
Resynchronize data from the source SVM The resync operation performs a rebaseline of the SVM configuration. You can resync from the source SVM to reestablish a broken relationship between the two SVMs. When the resync is complete, the destination SVM contains the same information as the source SVM and is scheduled for further updates.
Click Operations > Resync from Source SVM.
The Resync from Source SVM dialog box is displayed.
Select the Ok to delete any newer data in the destination SVM checkbox.
Click Resync.
Resynchronize data from the destination SVM (Reverse Resync) You can resync from the destination SVM to create a new relationship between the two SVMs. During this operation, the destination SVM continues to serve data with the source SVM backing up the configuration and data of the destination SVM.
Click Operations > Resync from Destination SVM (Reverse ReSync).
The Resync from Destination SVM (Reverse Resync) dialog box is displayed.
If the SVM has multiple relationships, select the This SVM has multiple relationships, Ok to release to other relationships checkbox.
Select the Ok to delete the new data in the source SVM checkbox.
Click Reverse Resync.
Reactivate the source SVM Reactivating the source SVM involves protecting and recreating the SVM relationships between the source and destination SVM. If you had selected the option to copy the source SVM configuration while creating the SVM relationship, then the destination SVM will stop processing data.
Click Operations > Reactivate Source SVM.
The Reactivate Source SVM dialog box is displayed.
Click Initiate Reactivation to initiate reactivation to the destination SVM.
Click Done.
SVM Relationships Window
You can use the SVM Relationships window to create and manage mirror relationships, and mirror and vault relationships between SVMs.
Command buttons
Create
Opens the SVM Disaster Recovery page, which you can use to create a mirror relationship, or mirror and vault relationship from a destination volume.
Edit
Enables you to edit the schedule and policy of a relationship.
For mirror and vault relationship, or version-flexible mirror relationship, you can modify the relationship type by modifying the policy type.
Delete
Enables you to delete a relationship.
Operations
Provides the following options:
Initialize
Enables you to initialize the SVM relationship to perform a baseline transfer from the source SVM to the destination SVM.
Update
Enables you to update data from the source SVM to the destination SVM.
Enables you to activate the destination SVM.
Enables you to initiate resynchronization of a broken relationship.
Enables you to resynchronize the relationship from the destination SVM to the source SVM.
Enables you to reactivate the source SVM.
Refresh
Updates the information in the window.
SVM relationships list
Displays the SVM that contains the volume from which data is mirrored and vaulted in a relationship.
Displays the SVM that contains the volume to which data is mirrored and vaulted in a relationship.
Is Healthy
Displays whether the relationship is healthy or not.
Relationship State
Displays the state of the relationship, such as Snapmirrored, Uninitialized, or Broken Off.
Transfer Status
Displays the status of the relationship.
Relationship Type
Displays the type of relationship, such as mirror, or mirror and vault.
Lag Time
Lag time is the difference between the current time and the timestamp of the last Snapshot copy that was successfully transferred to the destination system. The lag time will always be at least as much as the duration of the last successful transfer, unless the clocks on the source and destination systems are not synchronized. The time zone difference is automatically calculated into the lag time.
Policy Name
Displays the name of the policy that is assigned to the relationship.
Policy Type
Displays the type of policy that is assigned to the relationship. The policy type can be StrictSync, Sync, Asynchronous Mirror, Asynchronous Vault, or Asynchronous Mirror Vault.
Details area
Details tab
Displays general information about the selected relationship, such as the source cluster and destination cluster, the protection relationship that is associated with the SVM, data transfer rate, state of the relationship, details about the network compression ratio, data transfer status, type of current data transfer, type of last data transfer, latest Snapshot copy, timestamp of the latest Snapshot copy, the status of the identity preserve, and the number of volumes protected.
Policy Details tab
Displays details about the policy that is assigned to the selected protection relationship.
