The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Abort a mirror transfer with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to abort a volume replication operation before the data transfer is complete. You can abort a scheduled update, a manual update, or an initial data transfer.
Steps
Click Protection > Volume Relationships.
Select the relationship for which you want to stop the data transfer, and click Operations > Abort.
Click the Yes, I want to abort the transfer check box to confirm the operation.
Click the Keep any partially transferred data check box to retain the data that is already transferred to the destination volume.
Click Abort.
The transfer status is displayed as “Aborting” until the operation is complete and displayed as “Idle” after the operation is complete.
Related information
