Manage jobs with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to manage job tasks such as displaying job information and monitoring the progress of a job.
Jobs
Jobs are asynchronous task and typically long-running volume operations, such as copying, moving, or mirroring data. Jobs are placed in a job queue and are run when resources are available. The cluster administrator can perform all the tasks related to job management.
A job can be one of the following categories:
A server-affiliated job is placed in queue by the management framework to be run in a specific node.
A cluster-affiliated job is placed in queue by the management framework to be run in any node in the cluster.
A private job is specific to a node and does not use the replicated database (RDB) or any other cluster mechanism.
You require the advanced privilege level or higher to run the commands to manage private jobs.
You can manage jobs in the following ways:
Displaying job information, including the following:
Jobs on a per-node basis
Cluster-affiliated jobs
Completed jobs
Job history
Monitoring a job's progress
Displaying information about the initialization state for job managers.
You can determine the outcome of a completed job by checking the event log.
Job window
You can use the Job window to manage job tasks such as displaying job information and monitoring the progress of a job.
Command button
Refresh
Updates the information in the window.
Tabs
Current Jobs
This tab displays information about the job tasks that are in progress.
Job History
This tab displays information about all the jobs.
Job list
Job ID
Displays the ID of the job.
Start Time
Displays the start time of the job.
Job Name
Displays the name of the job.
Node
Displays the name of the node.
State
Displays the state of the job.
Job Description
Displays the description of the job.
Progress
Schedule Name
Displays the name of the schedule.
