The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Delete LUNs with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to delete LUNs and return the space used by the LUNs to their containing aggregates or volumes.
Before you begin
The LUN must be offline.
The LUN must be unmapped from all initiator hosts.
Steps
Click Storage > LUNs.
In the LUN Management tab, select one or more LUNs that you want to delete, and then click Delete.
Select the confirmation check box, and then click Delete.
Related information
