The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Set up a support page with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to set up a support page. Setting up the support page completes the cluster setup, and involves setting up event notifications, and for single-node clusters, configuring system backup.
Before you begin
You must have set up the cluster and network.
Steps
Set up the event notifications by using the mailhost, or SNMP trap host, or Syslog server.
You must set up at least one event notification system.
If you have a single-node cluster, configure a system backup on an FTP server or on an HTTP server.
System backup is applicable only for single-node clusters.
Click Submit and continue.
What to do next
View the storage recommendations and create SVMs to continue with the cluster setup.
