Cluster Update window with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use the Cluster Update window to perform an automated cluster update nondisruptively or you can update single-node clusters disruptively with ONTAP System Manager classic (available in ONTAP 9.7 and earlier).
Tabs
Cluster Update
Enables you to perform an automated cluster update nondisruptively or you can update single-node clusters disruptively.
Update History
Displays the details of previous cluster updates.
Cluster Update tab
The Cluster Update tab enables you perform an automated cluster update nondisruptively or you can update single-node clusters disruptively.
Command buttons
Refresh
Updates the information in the window.
Select
You can select the version of the software image for the update.
Cluster Version Details: Displays the current cluster version in use and the version details of the nodes or high-availability (HA) pairs.
Available Software Images: Enables you to select an existing software image for the update.
Alternatively, you can download a software image from the NetApp Support Site and add the image for the update.
Validate
You can view and validate the cluster against the software image version for the update. A pre-update validation checks whether the cluster is in a state that is ready for an update. If the validation is completed with errors, a table displays the status of the various components and the required corrective action for the errors.
You can perform the update only when the validation is completed successfully.
Update
You can update all of the nodes in the cluster or an HA pair in the cluster to the selected version of the software image. While the update is in progress, you can choose to pause the update, and you can then either cancel or resume the update.
If an error occurs, the update is paused and an error message is displayed with the remedial steps. You can choose to either resume the update after performing the remedial steps or cancel the update. You can view the table with the node name, uptime, state, and ONTAP version when the update is successfully completed.
Update History tab
Displays details about the cluster update history.
Update History list
Image Version
Specifies the version of the ONTAP image to which the node will be updated.
Software Updates Installed on
Specifies the type of disk on which the updates are installed.
Status
Specifies the status of the software image update (whether the update is successful or cancelled).
Start Time
Specifies the time when the update was started.
Completion Time
Specifies the time when the update was completed.
This field is hidden by default.
Time Taken for the Update
Specifies the time taken for the update to finish.
Previous Version
Specifies the ONTAP version of the node before the update.
Updated Version
Specifies the ONTAP version of the node after the update.
