Set up the cluster with System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manger classic (available in ONTAP 9.7 and earlier) to set up the cluster.
Setting up the cluster involves gathering the configuration information, creating cluster-management and node-management interfaces, adding licenses, setting up the cluster time, and monitoring HA pairs.
Update the cluster name
You can use System Manager to modify the name of a cluster when required.
Click Configuration > Cluster > Configuration Updates.
In the Cluster Details pane, click Update Cluster Name.
In the Update Cluster Name dialog box, specify a new name for the cluster, and then click Submit.
Change the cluster password
You can use System Manager to reset the password of a cluster.
In the Cluster Details pane, click Change Password.
In the Change Password dialog box, specify a new password, confirm the new password, and then click Change.
Edit DNS configurations
You can use System Manager to add host information to centrally manage DNS configurations. You can modify the DNS details when you want to change the domain names or IP addresses.
In the Cluster Details pane, click Edit DNS Configuration.
In the DNS Domains area, add or modify the DNS domain names.
In the Name Servers area, add or modify the IP addresses.
Click OK.
Create a cluster management logical interface
You can use System Manager to create a cluster management logical interface (LIF) to provide a single management interface for a cluster. You can use this LIF to manage all of the activities of the cluster.
In the Cluster Details pane, click Create Cluster-management LIF.
In the Create Cluster-Management LIF dialog box, specify a name for the cluster management LIF.
Assign an IP address to the cluster management LIF:
If you want to… Then… Specify the IP address by using a subnet
Select Using a subnet.
In the Add Details dialog box, select the subnet from which the IP address should be assigned.
For an intercluster LIF, only the subnets that are associated with the selected IPspace are displayed.
If you want to assign a specific IP address to the LIF, select Use a specific IP address, and then type the IP address.
The IP address that you specify is added to the subnet if the IP address is not already present in the subnet range.
Click OK.
Specify the IP address manually without using a subnet
Select Without a subnet.
In the Add Details dialog box, perform the following steps:
Specify the IP address and the network mask or prefix.
Optional: Specify the gateway.
If you do not want to use the default value for the Destination field, specify a new destination value.
If you do not specify a value, the Destination field is populated with the default value based on the family of the IP address.
If a route does not exist, a new route is automatically created based on the gateway and destination.
Click OK.
Select the required ports from the Port details area.
Click Create.
Edit the node name
You can use System Manager to modify the name of a node when required.
In the Nodes tab, select the node that you want to rename, and then click Edit Node Name.
In the Edit Node Name dialog box, type the new name for the node, and then click Submit.
Create a node management logical interface
You can use System Manager to create a dedicated node management logical interface (LIF) for managing a particular node in a cluster. You can use this LIF to manage the system maintenance activities of the node.
In the Nodes tab, select the node for which you want to create a node management LIF, and then click Create Node-Management LIF.
In the Create Node-Management LIF dialog box, specify a name for the node management LIF.
Assign the IP address to the node management LIF:
Click OK.
Click OK.
Select the required ports from the Ports details area.
Click Create.
What to do next
If you want to delete an existing node management LIF, you must use the command-line interface (CLI).
Edit AutoSupport settings
You can use System Manager to modify your AutoSupport settings to specify an email address from which email notifications are sent and to add multiple email host names.
Click
> AutoSupport. -
Select the node for which you want to modify AutoSupport settings, and then click Edit.
In the Email Recipient tab, type the email address from which email notifications are sent, specify the email recipients and the message content for each email recipient, and then add the mail hosts.
You can add up to five email addresses for each host.
In the Others tab, select a transport protocol for delivering the email messages, and then specify the HTTP or HTTPS proxy server details.
Click OK.
