Editing FlexGroup volumes
Beginning with System Manager 9.6, you can edit the properties of an existing FlexGroup volume.
The FlexGroup volume must be online.
FabricPool FlexGroup volumes can be expanded under the following conditions:
A FabricPool FlexGroup volume can be expanded only with FabricPool aggregates.
A non-FabricPool FlexGroup volume can be expanded only with non-FabricPool aggregates.
If the FlexGroup volume contains a mix of FabricPool and non-FabricPool volumes, then the FlexGroup volume can be expanded with both FabricPool and non-FabricPool aggregates.
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the FlexGroup volume that you want to modify, and click Edit.
Optional: If you want to rename the FlexGroup volume, enter the new name in the Name field.
Beginning with System Manager 9.6, you can also rename FlexGroup DP volumes.
Optional: Enable the Encrypted option to enable encryption for the volume.
This option is available only if you have enabled the Volume Encryption license and if the corresponding platform supports encryption.
Specify the percentage of the Snapshot copy reserve.
Optional: Click
to modify the FlexGroup volume settings. Refer to Specifying advanced options for a FlexGroup volume. -
Specify the size to which you want to resize the FlexGroup volume.
By default, existing aggregates are used to resize the FlexGroup volume. The minimum size that is allowed for the volume is displayed next to the size fields.
If you want to expand the FlexGroup volume by adding new resources, click
(advanced options). Refer to Specifying advanced options for a FlexGroup volume. -
Click Save to save the changes.
Related information
