The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Change the deduplication schedule with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the deduplication schedule by choosing to run deduplication manually, automatically, or on a schedule that you specify.
Steps
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the read/write volume for which you want to modify the deduplication schedule.
Click Edit, and then click the Storage Efficiency tab.
Change the deduplication schedule as required.
Click Save and Close.
Related information
