System Manager Classic
Manage nodes with System Manager - ONTAP 9.7 and earlier
Contributors netapp-barbe netapp-mwallis
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to view the details of the nodes in the cluster.
Initialize the ComplianceClock time
You can use System Manager to initialize the ComplianceClock time to the current cluster time. You must initialize the ComplianceClock time in order to create SnapLock aggregates.
Before you begin
The SnapLock license must be installed.
About this task
You cannot modify or stop the ComplianceClock time after it is initialized.
Steps
  1. Click Storage > Nodes.
  2. Select the node, and then click Initialize ComplianceClock.
  3. In the Initialize ComplianceClock dialog box, click Yes to initialize the ComplianceClock time to the current cluster time.
Nodes window
You can use the Nodes window to view the details of the nodes in a cluster.
Command buttons
  • Initialize ComplianceClock
    Initializes the ComplianceClock of the selected node to the current value of the system clock.
  • Refresh
    Updates the information in the window.
Nodes list
  • Name
    Displays the name of the node.
  • State
    Displays the state of the node (whether the node is up or down).
  • Up Time
    Displays the duration for which the node is up.
  • ONTAP Version
    Displays the ONTAP version that is installed on the node.
  • Model
    Displays the platform model number of the node.
  • System ID
    Displays the ID of the node.
  • Serial No
    Displays the serial number of the node.
Details area
Displays detailed information about the selected node.
  • Details tab
    Displays information related to the selected node such as the name of the node, the state of the node, and the duration for which the node is up.
  • Performance tab
    Displays the throughput, IOPS, and latency of the selected node.
    Changing the client time zone or the cluster time zone impacts the performance metrics graphs. You should refresh your browser to view the updated graphs.
