Manage protection policies with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create, edit, and delete protection policies.
Create protection policies
You can use System Manager to create cluster-level asynchronous mirror policies, vault policies, or mirror and vault policies, and to apply these policies to a cluster-level data protection relationship.
Click Protection > Protection Policies.
Click Create.
In the Create Policy dialog box, select the type of policy that you want to create.
Specify the policy name and transfer priority.
Low indicates that the transfer has the lowest priority. Low priority transfers are usually scheduled after normal priority transfers. By default, the transfer priority is set to Normal.
Optional: Select the Enable Network Compression check box to compress the data that is being transferred during a data transfer.
Optional: For an asynchronous mirror policy, select the Transfer All Source Snapshot Copies check box to include the “all_source_snapshots” rule to the mirror policy, which backs up all of the Snapshot copies from the source volume.
Optional: Click Add Comments to add additional comments for the policy.
For a vault policy or mirror vault policy, specify a SnapMirror label and a destination retention count.
Click Create.
Protection Policies window
You can use the Protection Policies window to create, manage, and display information about mirror, vault, and mirror vault policies.
Command buttons
Create
Opens the Create Policy dialog box, which enables you to create a mirror, vault, or mirror vault policy.
Edit
Opens the Edit Policy dialog box, which enables you to edit a policy.
Delete
Opens the Delete Policy dialog box, which enables you to delete a policy.
Refresh
Updates the information in the window.
Protection policies list
Name
Displays the name of the protection policy.
Type
Displays the policy type, which can be Vault, Mirror Vault, or Asynchronous Mirror.
Comment
Displays the description specified for the policy.
Transfer Priority
Displays the data transfer priority, such as Normal or Low.
Details area
Policy Details tab
Displays details of the protection policy, such as the user who created the policy, number of rules, retention count, and status of network compression.
Policy Rules tab
Displays details of the rules that are applied to the policy. The Policy Rules tab is displayed only if the selected policy contains rules.
