Auditing system and user activities
If you want to locate unexpected changes, you can view an audit trail of the OnCommand Insight system and its user activities. Audit log messages can optionally be sent to syslog in addition to being displayed on the Audit page.
About this task
Insight generates audit entries for any user activities that affect the storage network or its management, including the following:
Logging in
Authorizing or unauthorizing a path
Updating an authorized path
Setting global policies or thresholds
Adding or removing a data source
Starting or stopping a data source
Updating data source properties
Adding, editing, or deleting a task
Removing an application group
Identifying or changing the identification for a device
Create a user
Delete a user
User role change
Modify a user (Guest à Admin)
Logout of a user (either forced logout or manual logout)
Deleting an acquisition unit
Update License
Enabling backup
Disabling Backup
Enabling ASUP (Enabling Proxy on same page is reported in audit log)
Disabling ASUP (Disabling Proxy on same page is reported in audit log)
Security - re-key, change system passwords.
Removing/adding annotations on assets
CAC user logon / logoff
CAC user session timeout
Steps
Open Insight in your browser.
Click Admin and select Audit.
The Audit page displays the audit entries in a table.
You can view the following details in the table:
Time
Date and time that the changes were made
User
Name of user associated with the audit entry
Role
User account's role, which is guest, user, or administrator
IP
IP address associated with the audit entry
Action
Type of activity in the audit entry
Details
Details of the audit entry
If there is a user activity that affects a resource, such as a data source or an application, the details include a link to the resource's landing page.
When a data source is deleted, the user activity details related to the data source no longer contain a link to the data source's landing page.
You can display audit entries by choosing a particular time period (1 hour, 3 hours, 24 hours, 3 days, and 7 days), with Insight showing a maximum number of 1000 violations for the selected time period.
You can click a page number below the table to browse through data by page if there is more data than fits on a single page.
You change the sort order of the columns in a table to either ascending (up arrow) or descending (down arrow) by clicking the arrow in the column header; to return to the default sort order, click any other column header.
By default, the table displays the entries in descending order.
You can use the filter box to show only the entries you want in the table.
To see only the audit entries by the user
izzyk, typeizzykin the filter box.
