OnCommand Insight
Tips for designing reports
Several tips might be helpful when you are designing reports.
  • Determine whether you need to use current or historical data.
    Most reports only need to report on the latest data available in the Data Warehouse.
  • Data Warehouse provides historical information on capacity and performance, but not on inventory.
  • Everybody sees all data; however, you might need to limit data to specific audiences.
    To segment the information for different users, you can create reports and set access permissions on them.
