OnCommand Insight
Deleting inactive devices
Deleting devices that are inactive helps keep your data cleaner and easier to navigate.
About this task
To delete inactive devices from Insight, do the following:
Steps
  1. Create a new query or open an existing query.
  2. Choose either the generic device, host, storage,switch, or tape asset type.
  3. Add a filter for Is active, and set the filter to No.
    The results table displays only assets that are not active.
  4. Select the devices that you want to delete.
  5. Click the Actions button and select Delete Inactive Devices.
    Your inactive devices are deleted and will no longer be displayed in Insight.
