Customizing a report's output format and delivery
You can customize the format and delivery method of reports.
Steps
Open the OnCommand Insight Reporting Portal and select the report you want to customize and click […].
Click Properties > Schedule
You can set the following options:
Schedule when you want reports to run.
Format the report output.
Delivery print, save, or email the report.
Languages define the language the report is delivered in.
Click Create to produce the report using the selections you made.
