Configuring a client to support Smart Card and certificate login
Client machines require middleware and modifications to browsers to enable the use of Smart Cards and for certificate login. Customers who are already using Smart Cards should not require additional modifications to their client machines.
Before you begin
For the most up to date CAC and Certificate instructions, see the following Knowledgebase articles (Support login required): |
About this task
The following are the common client configuration requirements:
Installing Smart Card middleware, such as ActivClient (see http://militarycac.com/activclient.htm)
Modifying the IE browser (see http://militarycac.com/files/Making_AKO_work_with_Internet_Explorer_color.pdf)
Modifying the Firefox browser (see https://militarycac.com/firefox2.htm)
