Overview of boot media replacement - AFF A70, AFF A90
PDF of this doc site
Creating your file...
The boot media stores a primary and secondary set of system (boot image) files that the system uses when it boots. Depending on your network configuration, you can perform either a nondisruptive or disruptive replacement.
You must have a USB flash drive, formatted to FAT32, with the appropriate amount of storage to hold the image_xxx.tgz
You also must copy the image_xxx.tgz
file to the USB flash drive for later use in this procedure.
You must replace the failed component with a replacement FRU component you received from your provider.
It is important that you apply the commands in these steps on the correct controller:
The impaired controller is the controller on which you are performing maintenance.
The healthy controller is the HA partner of the impaired controller.
