Transfer the boot image to the boot media - AFF A800
PDF of this doc site
Creating your file...
The replacement boot media that you installed is without a boot image so you need to transfer a boot image using a USB flash drive.
You must have a USB flash drive, formatted to FAT32, with at least 4GB capacity.
A copy of the same image version of ONTAP as what the impaired controller was running. You can download the appropriate image from the Downloads section on the NetApp Support Site
If NVE is enabled, download the image with NetApp Volume Encryption, as indicated in the download button.
If NVE is not enabled, download the image without NetApp Volume Encryption, as indicated in the download button.
If your system is an HA pair, you must have a network connection.
If your system is a stand-alone system you do not need a network connection, but you must perform an additional reboot when restoring the var file system.
Download and copy the appropriate service image from the NetApp Support Site to the USB flash drive.
Download the service image to your work space on your laptop.
Unzip the service image.
If you are extracting the contents using Windows, do not use WinZip to extract the netboot image. Use another extraction tool, such as 7-Zip or WinRAR. There are two folders in the unzipped service image file:
boot
efi
Copy the
efi
folder to the top directory on the USB flash drive.The USB flash drive should have the efi folder and the same Service Image (BIOS) version of what the impaired controller is running.
Remove the USB flash drive from your laptop.
If you have not already done so, close the air duct:
Swing the air duct all the way down to the controller module.
Slide the air duct toward the risers until the locking tabs click into place.
Inspect the air duct to make sure that it is properly seated and locked into place.
Air duct
Risers
Align the end of the controller module with the opening in the chassis, and then gently push the controller module halfway into the system.
Reinstall the cable management device and recable the system, as needed.
When recabling, remember to reinstall the media converters (SFPs or QSFPs) if they were removed.
Plug the power cable into the power supply and reinstall the power cable retainer.
Insert the USB flash drive into the USB slot on the controller module.
Make sure that you install the USB flash drive in the slot labeled for USB devices, and not in the USB console port.
Gently push the controller module all the way into the system until the controller module locking hooks begin to rise, firmly push on the locking hooks to finish seating the controller module, and then swing the locking hooks into the locked position over the pins on the controller module.
The controller begins to boot as soon as it is completely installed into the chassis.
Interrupt the boot process by pressing Ctrl-C to stop at the LOADER prompt.
If you miss this message, press Ctrl-C, select the option to boot to Maintenance mode, and then
halt
the controller to boot to LOADER. -
Although the environment variables and bootargs are retained, you should check that all required boot environment variables and bootargs are properly set for your system type and configuration using the
printenv bootarg name
command and correct any errors using thesetenv variable-name <value>
command.-
Check the boot environment variables:
bootarg.init.boot_clustered
partner-sysid
bootarg.init.flash_optimized
for AFF C190/AFF A220 (All Flash FAS) -
bootarg.init.san_optimized
for AFF A220 and All-Flash SAN Array -
bootarg.init.switchless_cluster.enable
If External Key Manager is enabled, check the bootarg values, listed in the
kenv
ASUP output:-
bootarg.storageencryption.support <value>
bootarg.keymanager.support <value>
kmip.init.interface <value>
kmip.init.ipaddr <value>
kmip.init.netmask <value>
kmip.init.gateway <value>
If Onboard Key Manager is enabled, check the bootarg values, listed in the
kenv
ASUP output:-
bootarg.onboard_keymanager <value>
Save the environment variables you changed with the
savenv
command -
Confirm your changes using the
printenv variable-name
command.
