SnapDrive for UNIX commands fail with customized LD_LIBRARY_PATH
PDF of this doc site
Administration for Linux
Role-based access control in SnapDrive for UNIX
Installation and Administration for Solaris
Creating and using Snapshot copies in SnapDrive for UNIX
Installation and Administration for IBM AIX
Creating your file...
Your file is ready
SnapDrive for UNIX commands fail if there is a customized LD_LIBRARY_PATH
and also if snapcreate-check-nonpersistent-nfs
is set to off .
Workaround
Set the env
variable in a wrapper script to ensure that the variable is visible only to the SnapDrive binaries.
