SnapDrive storage create command fails when multiple SAN paths are present but multipathing is disabled
The SnapDrive storage create command fails when multiple SAN paths are present but multipathing is disabled.
For example, for two iSCSI LIFs for an SVM:
[root@scspr0189449001 etc]# iscsiadm --mode session --rescan Rescanning session [sid: 1, target: iqn.1992-08.com.netapp:sn.f7335762b23e11e695360050569c153a:vs.3, portal: 10.224.70.253,3260] Rescanning session [sid: 2, target: iqn.1992-08.com.netapp:sn.f7335762b23e11e695360050569c153a:vs.3, portal: 10.224.70.254,3260]
When multipathing-type is set to none in the snapdrive.conf file and the multipath service is disabled, trying a storage create using LVM, returns the following error:
root@scspr0189449001 etc]# snapdrive storage create -fs /mnt/test -lun rgvsim:/vol/asmvol/test -lunsize 500m
LUN rgvsim:/vol/asmvol/test ... created
mapping new lun(s) ... done
discovering new lun(s) ... *failed*
Cleaning up ...
- LUN rgvsim:/vol/asmvol/test ... deleted
0001-422 Admin error: LVM initialization of luns failed:
Device /dev/sdb,/dev/sdc not found (or ignored by filtering).
This happens because the pvcreate command uses both the devices separated by a comma as a single device pvcreate /dev/sdb,/dev/sdc and a device named /dev/sdb,/dev/sdc that does not exist.
When there are multiple paths to storage and LVM needs to be used, then multipathing must be enabled.
