SnapDrive for UNIX displays an error message after SUSE Linux Enterprise Server is upgraded from version 10 to 11
Download PDF of this page
SnapDrive for UNIX displays an error after you upgrade the SUSE Linux Enterprise Server (SLES) from version 10 to 11. You must create a base device name and mount the file system.
When you perform storage operations, SnapDrive for UNIX reports the following error: 0001-791 Admin error: Device /dev/sdc does not have a partition. A single partition is required to support a persistent mount for file system /mnt/testfs. Retry command with '-nopersist' option
Workaround
Use the options
-fs
and-nopersist
to record the base device name, as shown in the following example:IBMX336-250-111:/etc/udev/rules.d # snapdrive storage connect -fs /mnt/testfs -lun f3020-207-11:/vol/san1/lun200_0 -nolvm -nopersist`
A file system is not created as expected, but the base device name is recorded (in this case,
/dev/sdc
Create the
mkdir --p /mnt/testfs
directory in the base device name. -
Run
blkid
Specify the following:
UUID=239ae9a1-75fd-4faf-b9f4-a0b80bf7b62c /mnt/testfs ext3
Mount the file system:
#mount /mnt/testfs`
Display the storage options:
#snapdrive storage show -fs /mnt/testfs3
