Mounting a FlexVol volume fails in NFS environment
When you mount a FlexVol volume, an entry is added in the /etc/exports
file. In NFS environment, SnapDrive for UNIX fails, and an error message is generated.
The error message is
0001-034 Command error: mount failed: nfs mount: dub12137:/vol/vn_dub12137_testprisredo_0: Permission denied.
SnapDrive for UNIX might encounter the error message due to the option nfs.export.auto-update
set to off
. The option nfs.export.auto-update
controls whether the automatic updates are performed on the /etc/exports
file.
The AutoSupport does not send the message to the storage system when the FlexVol volume fails in NFS environment. |
Steps
Set the
optionon
so that the/etc/exports
file is updated automatically.SnapDrive for UNIX can now mount the FlexVol volume.
In an HA pair active/active configuration, ensure you set the NFS exports option on
for both the storage systems.
