Snapdrive for Unix
SnapRestore and Snapconnect operations does not work in Linux after multipathing type migration
Contributors netapp-ivanad
The SnapRestore and SnapConnect operations does not work if the multipathing type is migrated.
If you have an existing multipathing type set as None, and later you tend to change the multipathing type as NativeMPIO, when you execute Snapconnect and SnapRestore operations for the existing Snapshot copies, you might encounter an error message as "Unable to find multipathing software linuxnull as present in the snapshot".
Example for SnapRestore operation
snapdrive snap restore -fs /mnt/tstmp -snapname withoutmpio
0002-105 Command error: Unable to find multipathing software linuxnull as present in the snapshot
Example for Snapconnect operation
snapdrive snap connect -fs /mnt/tstmp -snapname
f3020-225-54:/vol/vol1:withoutmpio -autorename
