Network gateway requirements
Contributors netapp-perveilerk netapp-lhalbert
Follow these requirements and guidelines for network gateways or routers.
  • If set, the gateway for a given network must be within the specific network's subnet.
  • If you configure an interface using static addressing, you must specify a gateway address other than 0.0.0.0.
  • If you don't have a gateway, the best practice is to set the gateway address to be the IP address of the network interface.
