Remove SGF6112 cover
Contributors netapp-pcelmer netapp-perveilerk
Remove the appliance cover to access internal components for maintenance.
Before you begin
Remove the appliance from the cabinet or rack to access the top cover.
Steps
  1. Make sure that the SGF6112 cover latch is not locked. If necessary, turn the blue plastic latch lock one-quarter turn in the unlock direction, as shown on the latch lock.
  2. Rotate the latch up and back toward the rear of the SGF6112 chassis until it stops; then, carefully lift the cover from the chassis and set it aside.
    SGF6112 cover latch open
    Important Wrap the strap end of an ESD wristband around your wrist and secure the clip end to a metal ground to prevent static discharge when working inside the SGF6112.
After replacing the part, return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return & Replacements page for further information.
Related information
Replace NIC
