The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version. 11/11/2024 Contributors Suggest changes Create a GitHub issue Send us an email PDFs PDF of this doc site Collection of separate PDF docs Creating your file... This may take a few minutes. Thanks for your patience. Cancel Your file is ready OK The following is a complete list of commands are available for your E-Series storage system. CLI commands (Alphabetical List) Activate asynchronous mirroring Activate storage array firmware Activate synchronous mirroring Add array label Add certificate from array Add certificate from file Add drives to SSD cache Add member to consistency group Add volume to asynchronous mirror group Autoconfigure storage array Autoconfigure storage array hot spares Cancel asynchronous mirror group role reversal Capture or view an AutoSupport log Change SSD cache application type Check asynchronous mirror group consistency Check repository consistency Check storage array connectivity Check synchronous mirroring status Check volume parity Clear asynchronous mirroring fault Clear drive channel statistics Clear email alert configuration Clear storage array configuration Clear storage array event log Clear storage array firmware pending area Clear storage array recovery mode Clear syslog configuration Clear volume reservations Clear volume unreadable sectors Configure email alert settings Configure syslog settings Create asynchronous mirror group Create consistency group Create consistency group snapshot image Create consistency group snapshot volume Create consistency group snapshot volume mapping Create disk pool Create host Create host group Create host port Create initiator Create iSCSI initiator Create RAID volume (automatic drive select) Create RAID volume (free extent based select) Create RAID volume (manual drive select) Create read-only snapshot volume Create snapshot group Create snapshot image Create snapshot volume Create SSD cache Create storage array directory server Create storage array security key Create storage array syslog configuration Create synchronous mirroring Create volume copy Create volume group Create Volume Mapping Create volume in disk pool Deactivate asynchronous mirroring Deactivate synchronous mirroring Delete asynchronous mirror group Delete audit log records Delete certificates Delete consistency group Delete consistency group snapshot image Delete consistency group snapshot volume Delete disk pool Delete email alert recipient Delete host Delete host group Delete host port Delete initiator Delete iSCSI initiator Delete snapshot group Delete snapshot image Delete snapshot volume Delete SSD cache Delete storage array directory server Delete storage array login banner Delete storage array syslog configuration Delete syslog server Delete volume Delete volume from disk pool Delete volume group Diagnose controller Diagnose controller iSCSI host cable Diagnose synchronous mirroring Disable external security key management Disable storage array feature Display AutoSupport bundle collection settings Display AutoSupport message collection schedule Display storage array syslog configuration Display storage array user session Download drive firmware Download environmental card firmware Download storage array drive firmware Download storage array firmware/NVSRAM Download storage array NVSRAM Download tray configuration settings Enable controller data transfer Enable disk pool security Enable external security key management Enable or disable AutoSupport (all individual arrays) Enable or disable AutoSupport at the EMW management domain level… Enable or disable AutoSupport maintenance window Enable or disable host connectivity reporting Enable or disable ODX Enable or disable the AutoSupport OnDemand feature Enable or disable the AutoSupport OnDemand feature at the EMW… Enable or disable the AutoSupport OnDemand Remote Diagnostics feature at… Enable or disable the AutoSupport remote diagnostics feature Enable or disable VAAI Enable storage array feature Enable volume group security Establish asynchronous mirrored pair Export storage array security key Generate Key Management Certificate Signing Request (CSR) Generate web server Certificate Signing Request (CSR) Import storage array security key Increase capacity of volume in disk pool or volume group… Initialize thin volume Install root/intermediate CA certificates Install server signed certificate Install storage array external key management certificate Install trusted CA certificates Load storage array DBM database Recopy volume copy Recover disabled drive ports Recover RAID volume Recover SAS port mis-wire Re-create external security key Re-create synchronous mirroring repository volume Reduce disk pool capacity Register SNMP community Register SNMP trap destination Remove array label Remove drives from SSD cache Remove incomplete asynchronous mirrored pair from asynchronous mirror group Remove installed trusted CA certificates Remove installed external key management certificate Remove installed root/intermediate CA certificates Remove member volume from consistency group Remove storage array directory server role mapping Remove synchronous mirroring Remove volume copy Remove volume from asynchronous mirror group Remove volume LUN mapping Rename snapshot volume Rename SSD cache Repair Data Parity Repair volume parity Replace drive Reset asynchronous mirror group statistics Reset AutoSupport message collection schedule Reset AutoSupport message collection schedule Reset controller Reset drive Reset installed signed certificate Reset iSCSI IP address Reset storage array diagnostic data Reset storage array host port statistics baseline Reset storage array InfiniBand statistics baseline Reset storage array iSCSI baseline Reset storage array iSER baseline Reset storage array RLS baseline Reset storage array SAS PHY baseline Reset storage array SOC baseline Reset storage array volume distribution Resume asynchronous mirror group Resume consistency group snapshot volume Resume snapshot image rollback Resume snapshot volume Resume SSD cache Resume synchronous mirroring Retrieve an AutoSupport log Retrieve installed CA certificates Retrieve installed external key management certificate Retrieve installed key management CSR request Retrieve installed server certificate Retrieve installed trusted CA certificates Revive drive Revive snapshot group Revive snapshot volume Revive volume group Save asynchronous mirror group statistics Save audit log records Save auto-load balancing statistics Save controller NVSRAM Save drive channel fault isolation diagnostic status Save drive log Save input output controller (IOC) dump Save storage array configuration Save storage array controller health image Save storage array DBM database Save storage array DBM validator information file Save storage array diagnostic data Save storage array events Save storage array firmware inventory Save storage array host port statistics Save storage array InfiniBand statistics Save storage array iSCSI statistics Save storage array iSER statistics Save storage array login banner Save storage array performance statistics Save storage array RLS counts Save storage array SAS PHY counts Save storage array SOC counts Save storage array state capture Save storage array support data Save tray log Schedule automatic support bundle collection configuration Set asynchronous mirror group Set audit log settings Set AutoSupport Dispatch Size Limit Set AutoSupport message collection schedule Set certificate revocation check settings Set consistency group attributes Set consistency group snapshot volume Set controller Set controller DNS settings Set controller host port properties Set controller NTP settings Set controller service action allowed indicator Set disk pool Set disk pool (modify disk pool) Set drawer service action allowed indicator Set drive channel status Set drive hot spare Set drive service action allowed indicator Set drive state Set event alert filtering Set external key management settings Set FIPS drive security identifier Set foreign drive to native Set host Set host channel Set host group Set host port Set initiator Set internal storage array security key Set iSCSI host port networking properties Set iSCSI initiator Set iSCSI target properties Set iSER target Set read-only snapshot volume to read/write volume Set session Set snapshot group attributes Set snapshot group media scan Set snapshot group repository volume capacity Set snapshot group schedule Set snapshot volume media scan Set snapshot volume repository volume capacity Set SSD cache for a volume Set storage array Set storage array controller battery learn cycle Set storage array controller health image allow overwrite Set storage array directory server Set storage array directory server role mapping Set storage array ICMP response Set storage array iSNS registration Set storage array iSNS server IPv4 address Set storage array iSNS server IPv6 address Set storage array iSNS server listening port Set storage array iSNS server refresh Set storage array local user password or SYMbol password Set storage array login banner Set storage array management interface Set storage array password length Set storage array PQ validation on reconstruct Set storage array redundancy mode Set Storage Array Resource Provisioned Volumes Set storage array time Set storage array to enable or disable Automatic Load Balancing… Set storage array to enable or disable cache mirror data Set storage array tray positions Set storage array unnamed discovery session Set storage array user session Set synchronous mirroring Set target properties Set thin volume attributes Set tray attribute Set tray identification Set tray service action allowed indicator Set volume attributes for a volume in a disk pool… Set volume attributes for a volume in a volume group… Set volume copy Set volume group Set volume group forced state Set volume mapping Show array label Show asynchronous mirror group synchronization progress Show asynchronous mirror groups Show audit log configuration Show audit log summary Show AutoSupport configuration (for E2800 or E5700 storage arrays) Show blocked events Show certificate revocation check settings Show certificates Show consistency group Show consistency group snapshot image Show controller Show controller diagnostic status Show controller NVSRAM Show current iSCSI sessions Show disk pool Show drive Show drive channel statistics Show drive download progress Show drive performance statistics Show email alert configuration Show host ports Show installed root/intermediate CA certificates summary Show installed trusted CA certificates summary Show replaceable drives Show signed certificate Show snapshot group Show snapshot image Show snapshot volumes Show SNMP communities Show SNMP MIB II system group variables Show SSD cache Show SSD cache statistics Show storage array Show storage array auto configuration Show storage array cache mirror data assurance check enable Show storage array controller health image Show storage array DBM database Show storage array directory services summary Show storage array host connectivity reporting Show storage array host topology Show storage array LUN mappings Show storage array negotiation defaults Show storage array ODX setting Show storage array power information Show storage array unconfigured iSCSI initiators Show storage array unreadable sectors Show string Show synchronous mirroring volume candidates Show synchronous mirroring volume synchronization progress Show syslog configuration Show thin volume Show unconfigured initiators Show volume Show volume action progress Show volume copy Show volume copy source candidates Show volume copy target candidates Show volume group Show volume group export dependencies Show volume group import dependencies Show volume performance statistics Show volume reservations Specify AutoSupport HTTP(S) delivery method Specify the AutoSupport delivery method Specify the Email (SMTP) delivery method Start asynchronous mirroring synchronization Start consistency group snapshot rollback Start controller trace Start Disk Pool Full Provisioning Start disk pool locate Start drive channel fault isolation diagnostics Start drive channel locate Start drive initialize Start drive locate Start drive reconstruction Start FDE secure drive erase Start input output controller (IOC) dump Start iSCSI DHCP refresh Start OCSP server URL test Start snapshot image rollback Start SSD cache locate Start SSD cache performance modeling Start Storage Array AutoSupport Manual Dispatch Start storage array configuration database diagnostic Start storage array controller health image Start storage array iSNS server refresh Start storage array locate Start storage array syslog test Start synchronous mirroring synchronization Start tray locate Start volume group defragment Start volume group export Start Volume Group Full Provisioning Start volume group import Start volume group locate Start volume initialization Stop consistency group snapshot rollback Stop consistency group snapshot volume Stop disk pool locate Stop drive channel fault isolation diagnostics Stop drive channel locate Stop drive locate Stop drive replace Stop pending snapshot images on consistency group Stop snapshot group pending snapshot images Stop snapshot image rollback Stop snapshot volume Stop SSD cache locate Stop SSD cache performance modeling Stop storage array configuration database diagnostic Stop storage array drive firmware download Stop storage array iSCSI session Stop storage array locate Stop tray locate Stop volume copy Stop volume group locate Suspend asynchronous mirror group Suspend SSD cache Suspend synchronous mirroring Test alerts Test asynchronous mirror group connectivity Test AutoSupport delivery settings Test email alert configuration Test external key management communication Test SNMP trap destination Test storage array directory server Test syslog configuration Test the AutoSupport configuration Unregister SNMP community Unregister SNMP trap destination Update SNMP community Update SNMP MIB II system group variables Update SNMP trap destination Update storage array syslog configuration Validate storage array security key
