Add an LDAP client configuration
Contributors NetAppZacharyWambold netapp-ivanad
You can use System Manager to add an LDAP client configuration at the cluster level or the storage virtual machine (SVM) level if you want to use LDAP services. You must first set up an LDAP client to use LDAP services.
About this task
At the SVM level, you can add an LDAP client only for a selected SVM.
Steps
  1. Add an LDAP client configuration by using one of the following methods:
    • Cluster level: click advanced options > LDAP.
    • SVM level: click SVM > SVM Settings > LDAP Client.
  2. Click Add.
  3. Type the name of the LDAP client.
  4. Add either the Active Directory domain or the LDAP server.
  5. Click advanced options (advanced options), select the Schema, and click Apply.
  6. Specify the Base DN and TCP Port.
  7. Click Binding, and then specify the authentication details.
  8. Click Save and Close.
  9. Verify that the LDAP client that you added is displayed.
Related information
