Deleting an LDAP client configuration
Contributors netapp-ivanad
You can use System Manager to delete an LDAP client configuration at the cluster level or the storage virtual machine (SVM) level.
About this task
At the SVM level, you can delete an LDAP client only for a selected SVM.
Steps
  1. To delete an LDAP client configuration:
    • Cluster level: Click advanced options > LDAP.
    • SVM level: Click SVM > SVM Settings > LDAP Client.
  2. Select the LDAP client that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Delete.
  4. Verify that the LDAP client that you deleted is no longer displayed.
Related information
