Deleting Kerberos realm configurations
Contributors netapp-ivanad
You can use System Manager to delete a Kerberos realm configuration.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Services pane, click Kerberos Realm.
  4. In the Kerberos Realm window, select one or more Kerberos realm configurations that you want to delete, and then click Delete.
  5. Select the confirmation check box, and then click Delete.
