SMB configuration overview with the CLI
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You can use ONTAP 9 CLI commands to configure SMB client access to files contained in a new volume or qtree in a new or existing SVM.
SMB (Server Message Block) refers to modern dialects of the Common Internet File System (CIFS) protocol. You will still see CIFS in the ONTAP command-line interface (CLI) and in OnCommand management tools. |
Use these procedures if you want to configure SMB access to a volume or qtree in the following way:
You want to use SMB version 2 or later.
You want to serve SMB clients only, not NFS clients (not a multiprotocol configuration).
NTFS file permissions will be used to secure the new volume.
You have cluster administrator privileges, not SVM administrator privileges.
Cluster administrator privileges are required to create SVMs and LIFs. SVM administrator privileges are sufficient for other SMB configuration tasks.
You want to use the CLI, not System Manager or an automated scripting tool.
To use System Manager to configure NAS multiprotocol access, see Provision NAS storage for both Windows and Linux using both NFS and SMB.
You want to use best practices, not explore every available option.
Details about command syntax are available from CLI help and ONTAP man pages.
If you want details about the range of ONTAP SMB protocol capabilities, consult the SMB reference overview.
Other ways to do this in ONTAP
To perform these tasks with… |
Refer to… |
The redesigned System Manager (available with ONTAP 9.7 and later) |
System Manager Classic (available with ONTAP 9.7 and earlier) |
