SNMP configuration overview
Contributors netapp-thomi NetAppZacharyWambold
Using the ONTAP System Manager classic interface with ONTAP 9.7 or earlier, you can configure SNMP at the cluster management level; add communities, security users, and traphosts; and test the SNMP communication.
You should use these procedures if you want to configure SNMP access to a cluster in the following way:
  • You are working with clusters running ONTAP 9.
  • You want to use best practices, not explore every available option.
    Note
    There are a few steps in these procedures for which you must use the command-line interface.
Other ways to do this in ONTAP
You can configure SNMP access to a cluster using for all ONTAP 9 versions. You should use the appropriate procedure for your version of ONTAP.
To perform these tasks with…​
Refer to…​
The redesigned System Manager (available with ONTAP 9.7 and later)
The ONTAP command-line interface (CLI)
